Topic: ****************Partial list of car & parts****updated******
The Flash32
July 20, 2007 at 06:41:22 PM
This message was edited on July 23, 2007 at 09:16:14 PM by The Flash32
Here is just a partial list or stuff I have gone through. If you need something not listed, I might have it!!!
Racecar...currently a street stock w/ new aluminum body. Can run as a Pro or converted easily back to a F/S. 3 race old 355 cu. in motor. Call for details. This car is race ready. New 6.33 gear, 3 sp. saginaw trans., Ford 9" rearend, new alum. radiator, new belts & seat cover, set back cage, '72 Chevelle frame, 16 gal. fuel cell, new fuel line, new dist., fairly new 750 carb., this car has only been raced a few times, never bent or wrecked. $6500 firm I have more than that in the motor alone!!!
Rims w/ new tires
5 liteweight wheels with various size tires. All 4 3/4x5 10 in. wide $100 ea.
1 LW beadlock w/ new tire, 4 /34 & 5x5 bolt pattern (dual bolt pattern) $100 SOLD
1 beadlock 5x5 w/new tire $100
Rims w/used tires
2 LW 4 3/4 $25 ea. SOLD
4 4 3/4 $35 ea.
1 LW 5x5 $35
1 beadlock 5x5 $35
1 5x5 $35
1 LW rim 4 3/4 $25 SOLD
1 4 1/2 $10
All wheels 10" wide
2 racing tubes $10 ea.
1 used 4 core radiator $25 SOLD
1 used P.S. box $10
1 used manual steering box $10
2 stock oil pans $5 ea.
2 left turn claimer oil pans $30 ea.
2 sag. 3 sp trannys, 1 has 1 ear broke, 1 has 2 ears broke, internals are good. I'll throw in extra cases to go with them. $30 ea.
2 sag. 3 spds. 3 line $100 ea. SOLD
1 modified rear bumper $10
8 Speedpro pistons & stock rods, 4 valve relief, 30 over for 350. $100
*****Updated stuff**** still more to come!
4 stock cast 350 cranks $25 ea.
3 168 tooth flexpates $5 ea.
1 153 tooth flexplate $5
1 400 flexplate $5
1 168 tooth alum. flywheel w/brass insert $ 35
9" ford pumpkin w/6.00 gear 28 spline mini spool R&P used 1 time. $200
2 68-72 Chevelle rear ends 10 bolt 8.5, 1 complete, 1 needs axles & gears $50 for both
1 sbc steel flywheel 168 tooth $25
4 new sticks of black roll bar padding $10
1 461 head, 2.02 valves, screw-in studs, guide plates..$50
1 stock sbc cast intake #3919803 $25
1 19" 4 blade GM fan $20
2 3.42 R&P 10 bolt 8.5 GM $20 ea.
5 GM 8.5 ring carriers $ 10 ea.
More to come!!!!
Any question on this stuff, call me for details. I'll go through more stuff over the weekend!
(405)204-9593 or email me
Flash
New website!!!!!!!!!
www.flashracecarbodies.com
The Flash32
July 21, 2007 at 11:04:57 AM
ttt
Flash
The Flash32
July 21, 2007 at 02:53:17 PM
updated w/items sold
Flash
The Flash32
July 22, 2007 at 05:57:39 PM
ttt
Flash
