Topic: Changing Modified Classes and Need To Sell Lots of Parts!
Champ95
December 04, 2009 at 06:23:57 PM
Call Steve (405)570-8090
Chevy 383 Stroker (raced 3 nights since new)
  • 4340 Crank Shaft
  • Crower 6" Rods
  • Speed Pro Flat Top Pistons
  • Internally Balanced
  • MSD Distributor
  • Smiley's Racing Spark Plug Wires (new)
  • Holley Strip Dominator Intake
  • Aluminum Water Pump
  • Kevko Oil Pan
  • Dart Iron Eagle Heads (2.05in.-1.06ex.)
  • 49CC Combustion Chambers
  • 220CC Intake Ports
  • Roller Rockers
  • Chrome Molly Push Rods (new)
  • ARP Bolt Kit
  • Machine Work and Assembled at Folks Machine in Norman $5,000
Brasswell Alky Carb. Works great $400
Pinto Spindles w/Upper Ball Joint Holders with Swedge Tube & Hemi Ends $100/ea. side
9" Floater Hub to Hub with Bird Cages $800
  • Includes Rear Brake Floaters on Both Rear Wheels
  • Drive line includes 5.67 rear gear
  • Also includes swedge tube arms w/Heims
Brinn Transmission (approx. 10 race nights on it) $1200
Steel Drive Button $50
383 Chevy 4340 Steel Crankshaft (needs to be turned - approx. 12 race nights since new) $400
1pr. 64 cc Steel EQ Heads – Ran 3 nights, refreshed at Folks Machine and ready to bolt on $800
Aluminum Bell Housing $50 stock type
Dirt Works Headers $50
32 Gallon Fuel Cell $75
9" 3rd Member Pumpkin Assembly 5:14 Gears with Full Spool 31 spline $300
9" Steel Full Spool New $80
Adjustable J-Bar $60
J-bar $40
Wilwood Clutch Pedal with Master Cylinder $65
Biscuit Pull Bar with Heims $60
Aluminum Power Steering Pump w/lines and fittings (includes Vertical Res.) $230
Barry Grant Fuel Pressure Reg. $40
Fuel Log $30
Afco Coil Over with Shock $100
Aluminum Racing seat 17" w/cover $75
MSD Distributor and 6AL Box with MSD Blaster 2 Coil $400
Champ95
December 11, 2009 at 11:58:12 AM
Posted By: Champ95 on December 04 2009 at 06:23:57 PM
  • 4340 Crank Shaft
  • Crower 6" Rods
  • MSD Distributor
  • Kevko Oil Pan
  • Roller Rockers
  • ARP Bolt Kit
J-bar $40
Fuel Log $30
Carb is sold.
