Engines retain factory GM seals and are equipped with a high security secondary seal that is registered and documented to further the integrity of the program
GM 602 Crate Sprint Engine Program Pace Performance/ Race 1/ Blackshear Racing Engine
Base GM 602 Sprint Engine: $3975 Includes: Rear Cam Drive--Balance Hub with Drive Yoke
Entry level 602 Engine Package : Pace Performance/GM 602 Sprint Engine ~With rear cam drive installed, balance hub including drive yoke ~HD Alum water pump, Alum V groove pulley kit w/belts, ~Fuel pump &Thermostat block off plates, Water fittings ~ Holley 750 cfm Alcohol carb ARP Carb stud kit, Bypass fuel regulator, Carb fittings w/ fuel log, Carb spacer plate w/linkage kit ~Washable Air filter kit, Pace/Moroso plug wire set, NGK spark plugs ~Schoenfeld spec headers, MSD 6200 rpm rev limiter, ~8 qts of break-in oil w/ Wix racing filter. All parts and engine are race prepped including Dyno break-in and tuning.
Complete Total Package Cost $6950.00
Elite package upgrade: Stealth custom carburetor, Aeromotive bypass regulator, KRC water pump, KRC serpentine pulley kit w/tensioner, R2C air filter kit. Add $1850.00
Package does NOT include: battery, fuel pump, fuel lines, water lines or mufflers.
Contact: John McDevitt/Pace Performance 800-748-3748 Don Blackshear/Blackshear Racing 724-977-7424 Brad Hibbard/Race 1 330-540-7223
