Minnesota Dirt Track Racing
Forum: Minnesota Dirt Track Racing Forum (go)
Moderators: StanM
Topic: Sprint Car and parts for sale
martensracing
December 06, 2006 at 10:22:47 PM
2004 88/40 Schnee: hood, panels, petals, motor plates, complete front end (no hubs, brakes), radius rods (no heim ends), arms, torque tube, ball and housing, top wing and trees, master cylinder $1,000
Front End- complete front end (no hubs, brakes) $300
Rear End- 4.86 Standard Axle (Brake Man Rotor, no caliper) $500
Shocks- Pro- 6, 6-2, (6) 5, (2) 4-7, (2) 4-6, 3-8, (2) 3-7, 3-6, 3-5 $35 EACH
Afco- 1475, 1196, (3) 1195, 1194, 1176, 1175 $25 EACH
Birdcages- Steel Birdcages 4 rights, 7 lefts $10 EACH 1 Schnee aluminum left $30
Master Cylinders- (2) Tilton 1", Tilton 7/8", Wilwood 1" $10 EACH
Brake Calipers- (3) Wilwood rear calipers, ultra-lite; $20 EACH
(3) Wilwood fronts, (4) JFZ $15 EACH
Rotors- (2) aluminum fronts $10 EACH (2) aluminum outboards $20 EACH
Arms- (5) right (3) left rear arms for 40" $10 EACH (2) Front arms $5 EACH
Pitman Arms- (4) $10 EACH
Hydraulic Wing Sliders- (3) $10 EACH
Wing Trees for external wing- (2) rears $5 EACH (5) fronts $10 EACH
Rear Wing Tree for internal- $20
18" Radius Rods- (8) $5 EACH
Torque Tubes- (2) MPD torque tubes w/ ball and housing $30 EACH Sanders torque tube $20 Aluminum U-Joint $20
Kirkey Head Rest- $5
MD 50 Right Rears (6) $10 EACH
High-speed- (2) Kinsler $30 EACH
Fuel Pumps- (2) Hilborn $100 EACH DSR $150
Hilborn Injection 2 3/16 Excellent Shape w/ stacks, filters, restrictors and #14 long nozzles $1,000
Cast Iron Heads- 235cc Iron Eagles: cnc ported, new valve springs, titanium retainers 7/8 studs, TD shaft rockers $2,000 215cc Iron Eagle, 7/8 studs, guide plates, valves, and valve springs $800
New Steel taper covers- $20
Rocker Arms- 7/16 aluminum 1.5 and 1.6 (40) $5 EACH
Oil Pump- high volume stock mount $40
Push Rods- 7.8, 7.9, 8.0; .080 chromemoly (40 each length) $4 EACH
Timing Chain and Gear- 350 Chevy double $5
Fresh Vertex External Coil- Fresh from moose mags $25
Lunati Rev Kit- $25
Stud Girdles- 7/16 stud girdle (2) $20 EACH
Roller Lifters- (30) crane cam (30) crower $5 EACH
Open Headed 360- $4,500
Short Block- Lunati rods, manly pistons, stock steel GM crank, 4 races since fresh, new oil pump, good champ pan, 4 bolt main 350 Chevy, new cam bearings $600
Firesuits- pyrotech suits, black and white (1) fits 5' 10- 6' 0 130-160 lbs (1) fits 5'11"-6'1" 150-180 $150 EACH
Contact Tim or Jordan Martens
(605) 743-5549
(605) 214-0488
