Reply 1 to 5 of 5 |
November 29, 2011 at
08:48:12 PM
This message was edited on
10:33:04 PM by RRC
I am in process of fixing up a vintage sprint and for simplicity, I want to run a carb and gasoline. The trouble I'm having is a stock chevy pump won't clear my front motorplate and its mounting tabs allowing it to bolt on the block.If the bowl was lower, it would clear. Is there a pump out on the market for this application? Perhaps there is someone in a sprint series that runs a carb and has experienced a similar situation? thanks
November 30, 2011 at
08:33:32 AM
Posted By: RRC on November 29 2011 at 08:48:12 PM
We are using a piston type fuel pump on the traditional sprints that clears just barely. I would call Travis at Mora Motorworks on the specifics.
320-225-0075
07:04:37 PM
Thank you!
December 11, 2011 at
12:21:51 PM
Posted By: RRC on November 30 2011 at 07:04:37 PM
Thank you!
Those Race Pumps piston pumps put out a lot more pressure-flow than you need and Race Pumps will tell you to run their fuel pressure regulator.
I have a stock pump on my daughter's 305 trainer.
There is no fuel on the upper housing side of the pump so the mod does go through the housing. I siliconed it shut in the event that something fails allowing fuel to the housing. Mine is the pump with return but I believe 78 and older have no return.
I spaced the front motor mount with some 1/2"-20 nuts to give the pump some room as well. These move it forward about 3/8-1/2".
I have a picture and will be happy to e-mail it, but can't figure how to get it on this post. You can text or call with your e-mail address. Dave Becker 612-203-1760
03:57:21 PM
Thank you for the reply Dave. I sent you a message through the forum with the e-address...
Reply 1 to 5 of 5 |
