Minnesota Dirt Track Racing
Forum: Minnesota Dirt Track Racing Forum (go)
Moderators: StanM
Topic: SPRINT CAR PARTS with pictures and prices
Love2race
February 20, 2011 at 11:46:58 PM
This message was edited on February 21, 2011 at 10:44:57 PM by Love2race
[image]
#1 & 2 quick release hubs for $75 each
#3 pin hub for $15
#4-8, resorvior tanks for $40 each, your choice.
#9 for $20.
[image]
#1-4 FOR $10 each
#5-7 Make offer
#8 for $5
#9 for $10
[image]
New MSD Self-powered timing light for $199.
[image]
#1 New MSD 12LT cap and rotor for $50.
#2 Like New Longcare Durometer for $50.
#3 New 1.5" Drive Spud for $35 each
#4 New 1" Drive Spud for $25 each
#5 New Alum. Lightweight Magneto Hold Down for $25 each
#6 New Bronze Distributor Gears for $25 each
#7 New Smaller Radiator cap for $20 each
#8 New Peterson Fuel shut off for $90
#9 New Special Fill Breather Can for V-8 rear end for $99
[image]
Titanium Parts!!
#1 set of nose wing stands for $75
#2 set of nose wing stands for $75
#3 set of nose wing posts for $40
#4 set of King pins for $99
#5 set of King pings for $99
#6 set of nose wing posts for $40
#7 set of nose wing straps for $30
#8 set of top wing front t-posts for $99
#9 and 10 set of nose wing posts for $30
[image]
Titanium Parts:
#1 Throttle Pedal for $99
#2 Throttle Pedal for $75
#3 Used top for $50
#4 set of Nose Wing stands for $40
#5 Jacob Ladder for $99
[image]
#1 Water Pressure Tool: Make offer
#2 Tool to adjust the Power Steering gear: $30
#3 & 4 6 blades siper for $55 each
#5 Siper for $10
#6 Siper for $15
[image]
#1 New Rear End Saver for $50
#2 New KSE Half Steering mount for $35
#3 New Gauge Mount for $25
#4 New Bracket for seat for $10 each
#5 New Vmac Splined Rear Wheel Center for $99
#6 Used cross breathers for $30
[image]
#1 New one piece brake clamp with Titanium bolts for $150
#2 New one piece brake clamp for $110
#3 Used Magnesium one piece brake clamp for $90
#4 Used Aluminium one piece brake clamp for $80
#5 New Red Devil InBoard Rotor Clamp for $270
#6 New Wilwood Dynamic Mount Rotor Clamp for $250
[image]
#1 Used Red Devil LF caliper for $95
#2 New Red Devil LF caliper for $125
#3 New Red Devil LR/RR caliper for $260
#4 Used Wilwood Inboard caliper with bracket for $130
#5 New Wilwood Inboard caliper with brake pads for $160
#6 & 7 New Wilwood LF caliper for $99 each
#8 Used Wilwood LF Caliper for $65
[image]
New set of Weld front hubs for $385
[image]
New Pitman for $32 each
[image]
New front motor plate for $55 each
[image]
New RH steering arm for $35 each
New LH combo arm for $65 each
OR
Set of RH and LH arms for $100 each set
[image]
#1 Used DMI ankle saver steel torque ball for $135
#2 New for $130
#3 Used Mettic BIGGG Ball & housing for $300
#4-6 Used for $99 each
[image]
#1 & 2 New Sanders 16 splines U-joint for $230 each
#3 New 32 splines U-joint for $230
#4-9 Used U-joint for $99 each
[image]
#1-3 Used wing valve for $65 each
#4-6 Used wing valve for $45 each
[image]
#1 Diaphragm Bypass for $75 each (has 4 of them)
#2 Quick Release Pill holder for $30 each (has 4 of them)
#3-6 for $20 each
#7 Fuel Injection Filter for $70
#8 pill holder for $25
#9 "Y" Fuel Manifold for $35
#10 "W" Fuel Maniforld for $45
[image]
#1 Used fuel shut off for $30
#2 Used Peterson fuel shut off for $70
#3 Used for $60
#4-10 Used for $20 each
[image]
#1 New Shurloc Shifter for $125
#2 Used Shurloc Shifter for $85
#3 Used DMI Shifter for $95
#4 Used Shurloc Shifter with Titanium bolts for $95
#5 almost new old school shifter for $40
#6 New cable for shifter for $55
[image]
New front spindles for $99 each
New nuts with lock for $30 each
[image]
[image]
Note: All 5 sets of nozzles in wooden box are 18AS
Set of nozzles for $99 each.
[image]
#1 New Main Line Shut Off for $99
#2 SOLD
#3 New Brass Weight Fuel Pick-up for $25
#4 New Top Plate for Fuel Tank for $145
[image]
$50 each
[image]
$20 each (pick up only, will not ship)
[image]
$195 each (pick up only, will not ship)
[image]
New set of birdcages with bearings for $375
[image]
MSD box, New, updated, tested, and ready to use. for $375 each
[image]
#1-NEW for $125
#2-4 for $100 each, your choice
#5 for $80
#6 & 7 for $60 each your choice
[image]
#1 for $20 each.
#2-10 for $10 each.
[image]
[image]
[image]
[image]
[image]
[image]
This is partial list that I couldn't be able to list everything. Let me know if you can't find the part that you are looking for.
Email at [email protected] or text at 605-351-7831.
Thank you,
Greg
Gunderson Racing Inc.
Sioux Falls, SD
