Reply 1 to 8 of 8 |
January 06, 2025 at
04:28:23 PM
Outlaws now want 6 bolts holding the tank on instead of 4-this should sell a lot of new tanks and result in an even larger hole torn in the shell in a crash. Also what's with the rule about foam in the tanks?The rule has been there for a while and yet to see anyone running foam? Glad they want safety wire on the 5/16 bolts holding the tanks on!!LOL
January 07, 2025 at
12:44:52 AM
Posted By: oldtom on January 06 2025 at 04:28:23 PM
You do not just put a bolt in tank, you also put large fender washers on bolt inside tank. You then cover bolt with alot of tape to prevent wear on bladder. It worked years ago.
January 07, 2025 at
08:11:33 AM
While they are at it make larger tanks mandatory. Fuel stops suck.
January 07, 2025 at
08:12:50 AM
Posted By: linbob on January 07 2025 at 12:44:52 AM
new tanks all come with threaded inserts formed into the plastic-no washer AND the rules says no modifications allowed
January 07, 2025 at
08:49:36 AM
Coincedentally, have any tank manufacturers recently come on board to sponsor the series?
Just curious.
January 07, 2025 at
09:05:46 AM
Recommended, not required! Also, the bolt size is not specified.
January 07, 2025 at
10:10:53 AM
Have more than a single manufacturer of the fuel cells had issues with the tanks detaching?
Keep It Real
January 07, 2025 at
06:14:29 PM
Aearger tank for the longer races would be ok with me. But nobody s note books have notes on the weight of 50 gallons. Might be interesting.
Even though I may not know you, I
care what most of you think!
Reply 1 to 8 of 8 |
